Hardware is not functioning properly plz help
Mar 22, 2018
8
So for a while now my msi laptop has been have a lot of problems but i cant figure out what is causing it. I get really low fps in games and sometimes the task manager shows programs using 100 cpu, gpu, disk, memory. So i decided to take a user benchmark test but i dont know how to fix my laptop.
Here is the link to the benchmark test: http://www.userbenchmark.com/UserRun/8251102
The specs on my laptop are not the best but they should be able to run pretty much anything smoothly which is just not the case.
Please let me know if you have any solutions to this problem
I installed Advanced SystemCare and driver booster but it not seem to help. I also scanned my laptop for viruses with malwarebytes but it didnt help either.
I dont know what you mean by temps. Could you elaborate on that please
I monitored the temps and now i see that they are overheating. But can clean my laptop actually fix my fps problem and make my laptop function faster like it used to?
