I Ibartlett Commendable Aug 26, 2016 1 0 1,510 Aug 26, 2016 #1 Help! I'm just wondering wether or not the Fx-6300 is compatible with a gigabyte GA-970 because it's says about the bios and I'm not sure how to update them as its my first build
Solution Ecky Aug 26, 2016 Unless you're getting a screaming deal, I recommend against an FX-6300. It's 4 years old at this point and was not a stellar chip when it was new. However, it should be compatible with the GA-970.
Ecky Illustrious Feb 3, 2013 7,592 2 38,960 Aug 26, 2016 Solution #2 Unless you're getting a screaming deal, I recommend against an FX-6300. It's 4 years old at this point and was not a stellar chip when it was new. However, it should be compatible with the GA-970. Upvote 1 Downvote Solution
