Build Advice Havent built a pc in 7 years. Looking for advice
amber438
11
Hi
So I haven't built a pc in 7 years and I guess it's time for an upgrade to win 11. Currently on windows 10 amd fx-8350 chip gigabyte 990fxa-ud5 r5 Motherboard 24g ddr3 ram. I'm looking at the Ryzen 7 5000g chip. What would be a good Motherboard to pair with it? I don't game anymore just email download music and movies etc. I'd stay as is but I don't know how long my av will continue with win 10
Thanks for any help
Amber
If you’re not gaming you might just pick up a used Dell office pc that supports windows 11 and upgrade it.
If you’re building, maybe just grab a case, ryzen 5700g cpu, 32gb ram and whatever size nvme ssd you like etc. On the motherboard grab a b550 series board. You could look at b450 boards but be sure to grab one with bios flashback in case of any issues.
Reactions: amber438
Hi
Thanks for any help
Amber
Maybe something like this:
PCPartPicker Part List
CPU: AMD Ryzen 5 8600G 4.3 GHz 6-Core Processor ($160.00 @ Amazon)
Motherboard: Gigabyte B650 EAGLE AX ATX AM5 Motherboard ($139.99 @ Amazon)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory ($99.99 @ Amazon)
Storage: Western Digital Black SN770 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($39.99 @ SanDisk)
Power Supply: Corsair CX (2023) 650 W 80+ Bronze Certified ATX Power Supply ($54.99 @ Amazon)
Total: $494.96
Generated by PCPartPicker 2024-11-24 18:48 EST-0500
Reactions: amber438
Or with the older Ryzen 7 5000g chip you can save some cash:
CPU: AMD Ryzen 7 5700G 3.8 GHz 8-Core Processor ($159.00 @ Amazon)
Motherboard: Gigabyte B550M AORUS ELITE AX Micro ATX AM4 Motherboard ($89.99 @ Newegg)
Memory: G.Skill Ripjaws V 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory ($48.99 @ Newegg)
Total: $392.96
Generated by PCPartPicker 2024-11-24 18:56 EST-0500
Total: $392.96
Funny was looking at the B550M aorus elite MB.
I have 4 wd sata hard drives and one has 2 partitions, one c for os and one d is for programs. Do I have to get a new ssd for the os? My power supply i think is either 500 or 600 w. Don't remember. But it's old so ill replace. I have a tower case I like for all these drives (one for music, one for books and one for movies and videos) but some fans need to be replaced.
I guess it's could get a nas for the drives but didn't want to spend $$$
Thanks
Thanks
You could use your hard drives and save $40 but there is a night and day difference in using a computer equipped with an SSD in terms of speed and reponsiveness such that I wouldn't recommend it.
Thanks. I'll probably go for an ssd and keep the others till I save up. Thanks for your help? As i steam movies and music I'll probably double the memory too
