Hello gentlemen, I would like to know what you recommend me to do, with this problem that I have the question is that I have been assembling my pc little by little and on November 28 of this year I have bought a graphics card gtx 1650 super 4g GDDR6 One-Fan, The question is that since I installed it, when I turn on my PC, the monitor does not give an image at first although the fans are working, so I have to turn it off and turn it on again for it to work, this only happens if the pc It is off for 1 hour and then I turn it on, because if I turn it on in a shorter period of time, this does not happen. The mainboard of my pc is an Acer Veriton X2611G, this because I had never had this problem with the two previous graphics cards that I had a Rx 560 2GB and GT 610 2GB. My monitor is a hp brand and it is from my old PC that I bought in 2006 so it only has VGA output so I bought an HDMI converter cable so I could connect my previous card. What should I do guys, I still have the guarantee of my card so I could change it but apart from that little problem when turning it on, it works very well while the pc is on. A technician has told me that it is a minor problem and perhaps it is due to an incompatibility problem between the board that is from 2013 with the graphics card that is from last year. What do you recommend me to do?
