D
Deleted member 2804083
Guest
Just gonna get my specs out of the way:
Windows 10
GTX 970 (Clock +150, Mem +250)
i5-4690k (Stock 3.5m althought I have the auto-OC option enabled, turboclock I believe its called)
16GB DDR3 Ram
I've been having some issues with my CPU. Between a few minutes to 2 hours after booting my PC, one of my CPU cores will just seemingly stop functioning. For example, normally when I'm playing R6: Siege, my CPU (and all of its cores) will be at 100% usage, whereas when I'm suffering from this issue, 3 of my cores will be at 100% while one of them (usually core 2 or 3) will be at 0%. This caps my CPU to 75% possible usage, and if the affected core goes above 0% my system will completely lock up for a few seconds to at-most a full minute. The only way to fix it is to reboot my computer, but that's obviously only a temporary fix.
here are some images of in-game usage during Yakuza 0 and R6: Siege, in these images core 2 is afflicted. If I'm playing other games (specifically Skyrim) core 3 is the affected core:
View: https://imgur.com/a/q2DuK6i
I've tried manually setting the number of CPUs I have in Windows 10 to 4, and have tried disable core parking in regedit. I'm at a loss at what to do. Is this a sign of my CPU dying? I don't think I can afford to upgrade right now.
Windows 10
16GB DDR3 Ram
