Having problem doing a fresh install of xp
Murphy
11
Archived from groups: microsoft.public.windowsxp.newusers (More info?)
Currently my pc is having a dualboot between xp and
linux. When I try doing a fresh install of xp, during the
setup I was given 3 option
1) Setup windows xp on selected item, press enter.
2)Create partition in the unpartition space, press C.
3)Delete selected partition, press D.
And also the following:
C: partition 1 NTFS 17469mb
E: partition 2 unknown 102mb
partition 3 unknown 11304mb
partition 4 unknown 447mb
And when I choose D to delete selected partition, I was
only given the option to delete partition 1 which is xp,
it seems as though I was not given the option to delete
linux as well, so how am I going to do a fresh install,
making sure everything is remove?
On Thu, 23 Sep 2004 21:26:25 -0700, "murphy"
Did you use your cursor keys to select a partition, then choose "D" to
delete it?
Donald L McDaniel
Keep the thread intact
Post reply to original newsgroup
Hi,
To delete the Linux partitions you will need to use the Linux pdisk utility.
Boot with the Linux disk or floppy and use it to remove the unwanted ext2/3
and swap partitions.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Associate Expert - WindowsXP Expert Zone
www.microsoft.com/windowsxp/expertzone
Windows help - www.rickrogers.org
"murphy" <anonymous@discussions.microsoft.com> wrote in message
news:139e01c4a1ee$a73ce210$a301280a@phx.gbl...
