I bought a cheap Sapphire 4850, that came with a single slot pretty poor cooler, that was crashing whenever I run Crysis in large open areas(settings on high) at 1650x1050, due to the astronomical temps it was hitting, so I bought the Akasa Vortexx Neo, which I have attached to the card, form what I can tell very well- thin layer of paste, pads on all the memory chips, however when I run the PC it goes for about 1-2mins before it just shuts down. I managed to check GPU temps, and it was only at 45c.
I'm completely puzzled at why it won't work, could it be because I don't have a 4pin plug to plug cooler directly into card? Only have a 3pin cable which I'm putting straight into my mobo.
Any help would be much appreciated
