Hdmi Cable for connection from speakers to hdtv
skydream
38
Hey, I recently bought a hdtv 1080p with a speaker system that comes with it from bestbuy.
I was told to get a hdmi cable to connect the speakers to the tv with it. I bought the hdmi cable for $80 from bestbuy then when I went online to newegg I found out that they sell the hdmi cables on newegg for around 20$-30$,I'm wondering is there any major difference in these cables should I just get the newegg hdmi cables? Please help!
Speaker I bought:
http://www.bestbuy.com/site/olspage.jsp?skuId=8397889&st=%238397889&lp=1&type=product&cp=1&id=1183767791212
Hdmi Cable I bought from best buy:
http://www.bestbuy.com/site/olspage.jsp?skuId=8473403&st=%238473403&lp=1&type=product&cp=1&id=1188558641784
Hdmi Cable from newegg 20$ !!!
http://www.newegg.com/Product/Product.aspx?Item=N82E16812196106
No. They're digital. They either work or they don't. You got sucker'd.
See if you can return 'em.
The same cable when properly searched for can be had for less than $10w/shipping
Honestly, and I don't mean to be rude, but shouldn't this kind of research be done BEFORE you drop your dough on something???
the best connection is with HDMI Cable http://clink.com.au/hdmi/hdmi_cables.htm
