Question Headphone cable replacment
May 9, 2019
5
Hey,
I have a pair of razor headphones that use an aux cable.
The cable is damaged and no longer works, I'm looking to replace the entirety of the cable but instead of 3.5mm aux I want it to connect via USB.
Is this possible? Would need to be able to have functionality of headphones and microphone as I would be using it for my ps4.
Many thanks
No, if you want usb headphones, you will need to buy a new pair or a usb dac.
Headphones that use 3.5mm only accept analogue audio.
USB headphones only accept digital audio and have a built in digital to analogue converter, whic your headphones lack.
You can replace the cable, but you will need soldering equipment.
