[SOLVED] Headset lights still on after pc shutdown
IAmAEggHead
8
So yeah.... Is it OK to just unplug the pc while headset lights are still on?
IK probably a stupid question but I've been a bit paranoid as of lately....
USB ports in computers are often left on because it's expected people will charge their devices with them. It'd be no different than if you had it plugged in a phone charger and yanked it out.
Win 8 & 10 do not perform a true shutdown when you click power>shutdown option. It instead goes to a hybrid sleep.
If you wish for it to do a full shutdown then you need to hold the shift key down when you click shutdown or make yourself a new shortcut with shutdown /s /t 0 as the location.
If you want to have shutdown force close running apps then use shutdown /f /s /t 0 instead
