my notebook is an ASUS N550JK. STOCK (except i switch the disk drive for a hdd with a caddy and use an SSD as main drive).
CPU RELATED SPECS:
Well basicly the thing is:
I recently started to feel like my notebook is getting unusally hot.
so i did a AIDA64 stress test and i got the results which were temperature 95 (c) on the CPU and
"(17% max )Thorttling - overheating detected"
so at this point i took apart my notebook cleaned it and reapplied the thermal paste, long story short i even changed both of the CPU fans to new ones. everything sprakling clean +new fans.
the thermal paste apliance i did is i guess mediocre, i redid it twice since on the first time i felt like ive put to little paste. ( still its clearly much better than it was done in the factory cause it was awful like someone put the paste and just squezed it with the cooling systems, and practicaly no paste on the gpu)
now im getting better temperature around 85 (c) and "(38% max )Thorttling - overheating detected"
so the thing is i still think that 85 is on the high spectrum of temperature, but i guess for a notebook its i guess expected.
BUT the main question is about the message "(38% max )Thorttling - overheating detected"
i dont fully understand the concept of Throttling, but i guess the lower % the better and ofcourse seeing red text is always a bad sign.
so ill appriciate some advice regarding what might be the issue and what can be done to prolong the health of my notebook.
screenshot of aida64 atm.
CPU RELATED SPECS:
Motherboard:
CPU Type Mobile QuadCore Intel Core i7-4700HQ, 3300 MHz (33 x 100)
Motherboard Name Asus N550JK Series Notebook
Motherboard Chipset Intel Lynx Point HM86, Intel Haswell
System Memory [ TRIAL VERSION ]
DIMM1: Samsung M471B1G73QH0-YK0 8 GB DDR3-1600 DDR3 SDRAM (11-11-11-28 @ 800 MHz) (10-10-10-27 @ 761 MHz) (9-9-9-24 @ 685 MHz) (8-8-8-22 @ 609 MHz) (7-7-7-19 @ 533 MHz) (6-6-6-16 @ 457 MHz) (5-5-5-14 @ 380 MHz)
DIMM3: Samsung M471B1G73QH0-YK0 [ TRIAL VERSION ]
BIOS Type AMI (01/23/2014)
Processor Properties:
Manufacturer Intel
Version Intel(R) Core(TM) i7-4700HQ CPU @ 2.40GHz
Asset Tag Fill By OEM
Part Number Fill By OEM
External Clock 100 MHz
Maximum Clock 3800 MHz
Current Clock 2400 MHz
Type Central Processor
Voltage 1.2 V
Status Enabled
Upgrade Socket rPGA988B
Socket Designation SOCKET 0
HTT / CMP Units 2 / 4
Capabilities 64-bit
Manufacturer Intel
Voltage 1.2 V
Status Enabled
Capabilities 64-bit
