sqweeky Apr 4, 2021 40 2 35 Apr 18, 2021 #1 I have Ryzen 5 2600 and Asus rog strix b450 F-II. Im confused how many psu cord do I need to insert it. It has 8, do I insert 8 pin cpu cord also? I'm not doing overclock. Thanks
Solution rgd1101 Apr 18, 2021 should be in the motherboard manual what you need to do but if it have 8 pin, plug in the 8 pin
rgd1101 Don't Moderator Nov 7, 2011 73,313 3,855 176,290 Apr 18, 2021 Solution #2 should be in the motherboard manual what you need to do but if it have 8 pin, plug in the 8 pin Upvote 0 Downvote Solution
