Question Help a friend with a power supply
Jan 23, 2021
19
Hi guys!
My friends motherboard on his pre-built system (Y720 Cube-15ISH) is no longer working.
I want to know if I can put in a new ITX motherboard - of some other brand - in his PC to get it working again.
My biggest concern is the Power Supply, because I've learned that sometimes you can get a proprietary PSU to work with a consumers market motherboard.
This is the Power Supply in the system:
It says "24+6+4pin Power Supply" - will that work, if I buy a new Motherboard? Also - I can't see there's an 8-pin connector, will there be a 2-pin connecter to go along with the 6-pin for a GPU?
Thanks in advance!
Colif
Win 10 Master
that is the new PSU standard, ATX12VO
you would need to get an ITX motherboard that uses it.
everything runs off the motherboard but I am not 100% sure how it all works as I haven't looked into it too hard.
they must have their own motherboards as there aren't many ATX12VO motherboards yet from what I can find - https://www.anandtech.com/show/15763/first-atx12vo-consumer-motherboard-the-asrock-z490-phantom-gaming-4sr
or just replace PSU s well. i wonder if there are any other proprietary plugs you will run into.
19
Hi Colif
Thank you for taking the time to reply to my post.
I don't think it's the new PSU standard, considering it's from 2016/2017ish. Wouldn't a motherboard like this, support the PSU he has? I see it has a 4-pin connector on the motherboard and 24-pin:
Colif
Win 10 Master
i had this sneaking suspicion I was wrong, I was waiting for that.
24 Pin, 4 Pin 12V, 6 Pin PCI Express
that looks like a very limited PSU
Power Cables
  • 24-pin power to motherboard (always required)
  • 4/8-pin EPS12V power to CPU (always required)
  • 6/8-pin power to video card (normally required)
  • SATA power to storage devices (normally required)
  • MOLEX power to accessories (optional)
  • CPU fan & case fan power (required)
  • Power cable to system’s power supply (always required)
curious how it powers the cpu fan
looks to me like it only has a 6 pin, its not designed for 8 pin GPU.
new PSU looks like better idea again.
