Question Help a noob at pc
Any power supply with a wattage of about 500W will handle your PC pretty well. Imgur doesn't work for me, so i cant see the image yo attached
EDIT: Yes, that power supply will do wonders for your system :)
Well, off to a bad start since this would be classified as a 500W power supply by any reputable company. Offers way too much 5V and 3.3V, which means it is an older design. I would not use this to power a system built in the last decade or so.
Where are you buying from? Should be able to pick one out worth having.
Inplay PSUs are known for falsifying wattage ratings (they are typically 100 watts lower than advertised) and even more famously are known for falsifying their 80+ certifications, as they are not listed on the official 80+ website.
Only use that PSU if you are okay with your PC catching on fire one day in the near future.
And even the wattage ratings aren't that good! Faking 516W of +12V power on a "650W" power supply is a little like robbing a bank and taking all their pens instead of the money.
Reactions: General_Cool
