Help After Building
giliara
150
So I just finished building my computer and installing Windows 7. I tried to install drivers for my hardware, but i do not know if it was successful or not. I went to add and remove programs ad this is what i had. Please tell me if i got it right.
AMD Catalyst
Intel Management Engine Components
Intel USB 3.0 eXtensible Host Controller Driver
Microsoft .Net Framework 4 Client Profile
Microsoft Visual C++ 2010 x64 10.0.40219
Microsoft Visual C++ 2010 x84 10.0.40219
Realtek Ethernet Diagnostic Utility
Realtek High Definition Audio Driver
My MOBO was a Asus P8Z77-V LK and my GPU was a XFX Radeon 7870
if you go into 'Device Manager' does anything have a yellow exclamation mark? did you install the Intel Chipset Driver? also looks like you have a Asmedia USB 3.0 but i don't see a driver installed for that. and did you download the latest driver from amd.com?
OK I went to device manager and these things had yellow exclamation marks.
802.11n WLAN Adapter
Ethernet Controller
SM Bus Controller
Universal Serial Bus (USB) Controller
I am fairly certain I installed a chipset driver.
So, next step is,
you go to the ASUS site, search for the newest drivers for your mobo, and download the missing (yellow exclamation mark) drivers.
Install them (don't forget to restart after every single one), and you're good to go.
Simple as that :)
go to the url below and set the version to windows 7 and im guess you are using x64? download and install the 3 below and then see what still has exclamation marks. some of the other drivers on the site might be newer then what you installed off the cd. its up to you if you want to install the newer versions.
http://www.asus.com/Motherboards/Intel_Socket_1155/P8Z77V_LK/#download
Intel Chipset Driver V9.3.0.1019
Intel VGA Driver V9.17.10.2828
Asmedia USB 3.0 Driver V1.16.2.0
under chipset its the bottom one. save them to the desktop. if they are exe files just run them and follow the prompts. if they are zip files like the intel chipset. double click and in the windows that pops up click extract. then in the new folder that opens run the setup exe.
Intel Chipset Driver V9.3.0.1019 for Windows Win7 64bit---(WHQL).
