Help before I kill my PC!
flamethrower205
Illustrious
Jun 26, 2001
13,105
Ok, the damn floppy drive on my comp ain't working, and I don't know why. I've tried reseting irq's and all that jazz in BIOS, but it still doesn't work! It tells me IRQ 6 kis also being used by some other device, but it doesn't even say irq 6 exits! Please help before I throw this piece of trash out the window.
Sig of the week.
Don't throw it out yet. I have had sporadic problems with my floppy drive
since installing WinXP. Bought new drive and new cable. Still goes nuts
now and then.
I have no answer. Maybe someone else does.
:smile: <font color=blue><b>You get what you pay for...all advice here is free.</b></font color=blue> :smile:
Haven't heard of that one. I don't use my floppy drive often enough for me to notice...
What does it do?
<font color=red> If you design software that is fool-proof, only a fool will want to use it. </font color=red>
werent you one of the people who agreed in another thread that floppy drives should be discontinued or something like that?...
ironic...isnt it?
anyways...maybe you need a new floppy drive?
<b><A HREF="http://gamershq.madonion.com/compare2k1.shtml?2932776" target="_new">P4 + DDR333</A>=<font color=blue>OK</font color=blue></b>
i just did a search (im really bored) and it turns out you werent one of the people who said that floppies should be dead...
my apologies... :wink:
When you insert a good disk, it says it isn't formated and asks if you want to format.
Boot to Win2k and it works fine.
Strange huh?
see mine doesn't even let me access the floppy. Rather, in system properties under hardware it says floppy is sharing IRQ w/ another device. I need floppy cause I don't want to waste a CD every time I move a file to old comp.
edit: by not access floppy I mean it doesn't even appear in my computer.
Sig of the week.<P ID="edit"><FONT SIZE=-1><EM>Edited by flamethrower205 on 03/18/02 05:44 PM.</EM></FONT></P>
ditto...just incase this happens to me...
<b><font color=red>ATI</font color=red>'s drivers are like a broken faucet, they both keep on leaking...</b> 😎
Sure....but I'll tell you guys the easier and more secure method which I found out today works. Basically, XP installs this thing called TPKD which is some antipiracy crap, but this may cause conflicts, and give u certain errors, one of these being that your floppy IRQ doesn't have enough resources. This can be fixed by a driver update for it.
Sig of the week.
