[SOLVED] HELP!! BSOD intermittently a few minutes after boot
DIIIIIII
107
Hi Guys!
Recently my partner's system has been experiencing some Intermittent BSOD's about a minute after it boots to windows, I've attempted to single out the possibility that the blue screens were linked to a new hardware/software change however she assured me nothing had changed that she was aware of. Upon checking the minidump using WinDbg, it seems the blue screen is linked to a USBhub3 driver but I'm not 100% certain as I'm a bit of a novice at interpreting what the program spits out.
I was hoping someone with a more keen eye for troubleshooting blue screens might be able to help us out.
Please see the mediafire link to a few of the mini dumps below, any help is appreciated!
https://www.mediafire.com/file/wl5ohkc4i20ysc9/Minidumps.zip/file
Cheers,
Dejan
I will see what they show me
Conversion of dumps
report - Click run as fiddle to see report
File: 092122-11171-01.dmp (Sep 21 2022 - 16:59:39)
BugCheck: [DRIVER_POWER_STATE_FAILURE (9F)]
Probably caused by: memory_corruption (Process: System)
Uptime: 1 Day(s), 9 Hour(s), 48 Min(s), and 00 Sec(s)
File: 092022-13687-01.dmp (Sep 20 2022 - 07:11:07)
Probably caused by: memory_corruption (Process: csrss.exe)
Uptime: 2 Day(s), 13 Hour(s), 10 Min(s), and 14 Sec(s)
What are full specs? I can see this but not storage or Power Supply info
CPU: 10600k
Motherboard: Gigabyte Z590 Vision G
RAM: 16gb GSkill Trident Z RGB F4-3000C15-8GTZR
GPU: Nvidia something...
Conversion of dumps
CPU: 10600k
logitech keyboard?
nothing obvious but it could be this
Jan 23 2012sixaxis.sysWireless Controller driver (Sony Computer Entertainment Inc.)
mainly based on age
or this
May 29 2015netr28ux.sysRalink Wireless Adapter driver https://www.mediatek.com/
It could be GPU drivers as I have seen that error with them before
try running ddu in safe mode, uninstall the GPU drivers, log back into normal mode and either:
  1. get drivers from Nvidia or;
  2. Run windows update and allow it to get older drivers that might be more stable
first time I seen this driver before, realtek USB Audio driver. Could tie into the sound connections on front. Its only on the more expensive boards from what I can tell.
Jan 06 2021RtUsbA64.2277.sys
there is a newer version of it now
https://www.gigabyte.com/Motherboard/Z590-VISION-G-rev-10/support#support-dl-driver
have you got the Gigabyte App centre installed?
The version of RGB fusion from 2019 makes me think you don't
App centre can be a pain to use but it would at least show newer drivers. (Its under utilities in the last link)
if you run it, make sure to untick the tick in the circle of every header area in the application or it will try to install everything, and you don't want everything
or just uninstall RGB fusion unless you use it for color patterns or something. I only used it to change the color on mb.
