Help Build Gaming Computer
KirielLight
15
Hi guys, I would like to build a gaming computer worh ₱60,000.00.
I will be getting my components from this site https://dynaquestpc.com/
Can you please help me which components to pick on that site? I would like to play witcher 3 on ultra 60fps.
Thanks
Here is a rough build, you still need a CPU cooler and windows. I went over budget, but it's very close to find variations of a build that would work for you. Try follow this build as a guideline and post complete build on the forum to get reflection on it (but remember this one i put together with "rough" emphasized thats why i say to use it as guide). Im fairly certain that the i5-7600k will work with win7, you can also double check that. These components can easily be switched out for better priced ones
Intel Core i5-7600K 3.8-4.2 Ghz 4-core Kaby lake Processor × 1 ₱12,560.00
Asus Prime Z270-A × 1 ₱11,290.00
GSkill Ripjaws V 16GB Dual DDR4 3200 (F4-3200C16D-16GVKB) × 1 ₱6,290.00
MSI GTX 1070 Gaming Z Twin Frozr 6 8GB × 1...
That's a pain in the butt website, most likely no one will help you 😛
but looking at some prices, I think you could pull off either
i5-7500+gtx1070
or
i5-7600k+gtx1060
somewhere around that. don't forget the 7xxx CPU take windows 10 (some exceptions such as the 7600k, if i remember correctly)
I don't really find that website a pain in the but. There are navs for each components and you can sort it to price or whatever. There is also a search box. Thanks for the tip anyway, I didn't know that the 7s take win 10 only. As for the components, I need suggestion for each of it, the brand and variant too.
Thanks again. n.n
MSI GTX 1070 Gaming Z Twin Frozr 6 8GB × 1 ₱26,750.00
Corsair CX750 750W 80Plus Bronze Power Supply × 1 ₱4,200.00
Corsair Carbide Series 200R Window Edition Casing × 1 ₱3,350.00
Subtotal ₱64,440.00
Shipping Pickup
Total ₱64,440.00
Thanks..I will consider this one..
