Help building my 1st PC
soldier17live
36
So I'm building my first PC and this is what I've got based off another user's suggestion.
http://pcpartpicker.com/p/CCBy
I want to know if the case is compatible with the motherboard, graphics card, and power supply, just basically if everything will fit inside and work properly. I think I'm also getting a different CPU cooler and was wondering if I should upgrade my power supply for the card I'm using(GTX 660)? Any advice would be great. Thanks
Cool, thanks for the help man. I was flipping out that after I ordered everything the parts wouldn't fit in and it'll be good to save a few bucks by not buying a CPU cooler. The added wattage will also ensure a well running system. Thanks
I guess I will get a CPU cooler just to be safe, thanks for the tip. I'm just so tired of console gaming and am loving the idea of a gaming PC.
i didnt say you cant run with stock cpu. i said that it would be better with a better cooler.
Maybe I'll just stick to the stock CPU for now, but I'm upgrading the PSU. Also do you think I can run graphic intensive games like crysis 3 on this rig?
you should understand that what im saying is basically this; on idle it will run maybe 5degress lower (Celsius), and under load we can maybe see around 10degress decrease.
now for 15$ I think it's worth it. Ive had a computer with a stock cooler, under intense games it would crash cuz of the CPU temps.
but for what it is. A 15$ ~ low noise (for price) and Cooler temps. not better?
still up to him to buy it or not
btw i listed this one, cuz before i clicked on wrong one
http://pcpartpicker.com/part/rosewill-cpu-cooler-rcxzaio92
