[HELP!] Case h700i Front Panels
Aug 18, 2018
12
My motherboard does not have these pins for the front panel like in the picture below.
88VDJbF
What should I do? My case is h700i and my motherboard Asus z170-a. Thank you!
I highly doubt it, most cases and motherboards are standardized these days. Can you take a picture of all your case connectors? Please make any writting visible. Also add your case and motherboard model
No wrong cable man, those ones are for the caze buttonzs, light, reset button, power button. You will have a large blue connector for USB 3.0 and a standard connect that needs to be connected to the USB 2.0 ports om your Motherboard.
I suggest you pull out the guidebook on your Motherboard, it will show you exactly where to connect what
Yes, I know about the USB 3.0 connector. The thing is that my case h700i has the cables for the case buttons but it isn't attached to anything as if I needed some kind of adapter from the case in order to plug the case bottons to my motherboard, but I don't see any. I'm just so confused.
