[SOLVED] Help choosing a cooler for overclocking i9-10900, w RAM clearance
neonplants
18
Hey all,
I completed my first streaming build a month or so ago.
Turns out I’m doing more intense stuff in OBS and After Effects than expected, so I want to correct my mistake and upgrade my CPU.
Looking into getting a new i9-10900. I had a bad experience trying to install the 212 EVO, so I ended up using the stock cooler for the first month of use.
Now that I’m looking at a much faster CPU, I need a cooling unit that will:
  • Be easy to install, easier than the 212
  • have enough clearance for my current RAM
  • be able to handle eventual overclocking of the new i9
Can anyone recommend something that will fit all that?
Also, will my current PSU be able to handle the new CPU?
Here’s what I have currently:
PCPartPicker Part List: https://pcpartpicker.com/list/jsXBBZ
CPU: Intel Core i5-9400F 2.9 GHz 6-Core Processor ($163.11)
Motherboard: MSI MPG Z390 GAMING EDGE AC ATX LGA1151 Motherboard ($189.99 @ Amazon)
Memory: G.Skill Ripjaws V Series 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory ($146.26)
Storage: PNY CS900 500 GB 2.5" Solid State Drive ($59.80)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive ($54.99 @ Newegg)
Video Card: Gigabyte GeForce GTX 1650 SUPER 4 GB WINDFORCE OC Video Card ($173.99)
Case: NZXT H510i ATX Mid Tower Case ($99.99 @ Best Buy)
Power Supply: Thermaltake Smart 600 W 80+ Certified ATX Power Supply ($78.02)
Capture Cards: (2) Elgato Game Capture HD60 Pro, stream and record in 1080p60, superior low latency technology, H.264 hardware encoding, PCIe ($179.99 @ Best Buy)
Thanks!
Hey all,
Here’s what...
Hey all,
Thanks!
So you know, you will need a new motherboard for a 10900. Finding one for a decent price will be difficult as well. If planning to change the motherboard and CPU I’d go with a Ryzen 3900x. If planning to get a 10900k, then you will want a noctua nh14, nh15 or an AIO water cooler.
In reference to your PSU question, I wouldn’t use it for a system that’s gonna be stressed a lot. It’s a good office pc basic task type PSU.
Damn, thank you for alerting me to that.
If I get the 9900k instead, which I think would work with my motherboard, do the same cooler recommendations apply?
A 9900k will work. You’ll have to test it’s capability with that boards VRM, holding a sustained max clock might cause a bit of throttling. Definitely want a big air cooler I think with a 9900k to push air across that VRM.
I would look at the 10700K instead of the 9900K as it is 100 bucks cheaper and runs cooler. In fact it is a 9900K which a better tim and shaved top design...so this would mean the Z490 motherboards and a mid range one like the Gigabyte Vision D, Asus Strix E or F, MSI Unify etc are all ready for next gen PCIe 4 and you will be able to upgrade to Rocket Lake CPU's when they come out next year...
A 240/280mm AIO would do a great job if overclocking but a good Air cooler in the Noctua/Dark Rock range will also work great...
his motherboard doesn't support 10700k the best cpu he can get is 9900k
