[SOLVED] Help! Compatible CPU for my Motherboard
Apr 18, 2020
Hello, I'm looking for some help to find the most powerful or best CPU to buy that is compatible with my Motherboard because I'm upgrading some parts of my current system and intend to use it primarily for gaming as well as some video editing. Also, would there be any BIOS update or required for Drivers required for the CPU to run properly.
I would also like to know if this website is a good reference for my motherboard and if I need any to do anything particular like update the BIOS or install new drivers for everything to work properly.
https://www.gigabyte.com/Ajax/SupportFunction/GetCpuList?Value=3901&Type=Product
Thanks for the help!
- Current System -
CPU: Phenom II X4 955
Motherboard: Gigabyte GA-990FXA-UD3
RAM: 16GB 1600MHz DDR3 RAM
PSU: Thermaltake TR2 450w 80+
- Upgrades -
GPU: Gigabyte RX 570 4GB (Dual Monitor)
CPU Cooler: CoolerMaster Hyper T4 Universal
- Current System -
RAM: 16GB...
- Current System -
- Upgrades -
Probably either FX8370 or Phenom II X6 1100T, depending on your feelings about FX processors. Either may be hard to find.
You'll probably need a BIOS update. Just update to the last BIOS released should do it. Just download the chipset drivers for your 990 (9 Series) chipset motherboard from AMD's web site
the fx 8350 and x6 1100t will be the best but i suggest you to sell your mobo and cpu bundle and get the better platform like b85 and i5 4th gen , much better artitechture and performance for cheap
Thanks for the Reply.
I can't really jump ship to Intel because of something about the RAM so I'm going to look at upgrading to the FX 8K range.
I looked around a bit and the best I could find was an FX-8350 on auction on eBay which is actually great. I'll see if I can pick it up and follow through with the RX-570 upgrade and see how it goes.
