[SOLVED] Help controlling Gigabyte graphics card LED lights
Oct 13, 2019
16
Hi there,
I am trying to find out how the lights on the Gigabyte GeForce RTX™ 2070 GAMING OC WHITE 8G are controlled. I will be using an Asus x570 motherboard. Does the motherboard control the lighting or is that done by the card itself using Gigabyte's software? This is my first PC build so even a basic answer will be very helpful.
