• Now's your chance win big! Join our community and get entered to win a RTX 2060 GPU, plus more! Join here.
    Pi Cast Episode 3 streams live on Tuesday, August 4th at 2:30 pm ET (7:30 PM BST). Watch live right here!
    Catch Scharon on the Tom's Hardware Show live on Thursday, August 6th at 2:00 pm ET (7:00 PM BST). Click here!
Question Help cpu cooler installation problem
May 15, 2020
15
I bought out of the box cpu cooler it has 3 pin my motherboard has 4 pin at cpu cooler socket ,how to connect to 4 pin socket ? I have connected to 3 pin sys fan socket it was very loud at first after that sound was stopped pls help me to fit in cpu socket my motherboard model g41
May 29, 2020
43
a 3 pin fan can be plugged on a 4 pin socket. However the 4th pin is the speedcontrol.
I wonder how an cpu fan has 3 pin only. I have not heared of that before.
Maybe you can post a picture?
May 29, 2020
43
How do i connect this 3 pin to 4 pin socket
There is only one way. Align the two liners of the connector with the standing wall on the header. dont apply much force.
If you have to apply much force, something doesnt fit right and you are likely to bend the pins on the board.
try to locate the CPU fan header on the board. It should have 4 pins.
If, on startup you receive a cpu fan or pwm error but the fan is actually spinning, there might be an option in the bios menu to disable cpu fan check (Since you do not have a pwm pin)
Keep in mind that this means no warning if your cpu fan is not spinning. If that ever was the case,
May 15, 2020
15
Thank so much dear
