Hi,
I had to shut down my laptop manually after it got stuck by holding the shutdown button, and when I turned it on there was a blue screen, and a message in the sort of "a required device cannot be found, or it is removed" or something like that (I didn't disconnect anything).
So I boot it up from the Windows 10 64 CD (that's the OS I have), and after trying out many fixes on the internet, I bumped into the diskpart fix, and I changed the active partition to another one, to see if it's the problem .
After doing that, windows gave me a "no OS could be found, please press ctrl+alt+del to restart"
Then I boot it up from the Windows CD again, and after the windows loading screen it remains stuck on a black screen (It was loading the boot disc slow before too, but it loaded it up in a few minutes, here I let it run for about an hour without success.)
What can I do?
I have been on this for about 8 hours non stop now and I am REALLY worried.
I downloaded the partition wizard tool which got into a problem too,
and also hiren's boot CD-and in hiren's boot CD I changed the partition and it didn't help (I even got a different message without a blue screen but a black screen on the sole partition on which it didn't give me the "no OS found" message".
Now hiren's boot CD has finally loaded the DOS programs (I think it is called that way) and I will be trying the partition manager when it finishes loading, maybe it will be different than the other partition choosing option that hiren's boot CD has.
I also have no idea why everything is SO slow with the CDs, also with the Win CD which in the installation was much faster.
Please help me, I am so lost and quite afraid, particulary because this computer belongs to my father, and has important files.
Thank you so much!
What can I do?
Thank you so much!
