73141 :
Ok I am wondering if the PSU that comes with this bundle (http://www.newegg.com/Product/ComboBundleDetails.aspx?ItemList=Combo.1935034) will be strong enough to power everything else plus (http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204). If the PSU won't work, or you know of a better PSU please tell me.
Hi - The issue isn't whether a decent quality 530w PSU would power that system, it will. The real problem
you may have is the quality of Raidmax PSU's is bad, actually very bad. Your system is using a low
power GPU, so you can get by with the Raidmax for a while, but I'd save $ to upgrade, or do so now
if you can afford to.
If so, post your budget and I'll suggest some alternatives.
