[SOLVED] Help finding solid Print Screen to Printer software
Nov 26, 2021
7
Hey there,
I've been using Gadwin Printscreen for a while. I had it set up to print out my window when I pressed a hotkey. Lately it has been resizing the images and printing them out way too small, and I cannot figure out how to resize properly.
If you have experience with Gadwin Print screen and know how I could fix this issue let me know.
Or if anyone out there has recommendations for a good, free, print screen software with the ability to send the image to a printer that would be great. Having the ability to customize is a bonus.
Thanks!
Thank you for your reply.
I will experiment with that solution, however it seems that it requires multiple steps.
I am really looking for a one-click (or press) or two-click solution to easily snapshot a window and print it simultaneously.
