[SOLVED] Help finding what crashes my system
Blingbo
90
I've had hard crashing happen multiple times over many games (fortnite, the new star wars, euro truck simulator 2, no mans sky, etc.) first thought is overheating, because fans go crazy, but I've monitored temperatures while running some of the listed games and were well below critical temps (~75C on GPU,~50C on CPU). I have l these logs from the event viewer, all describing "The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly." Could it be my PSU? Cause it's failed once and had it replaced under warranty. It crashes just like hard restarting, no BSoDs
My PCs parameters are:
Win 10 Pro x64
AMD FX-8350
MSI 970
DDR3 16GB, 2 kits 2x4GB
MB Gigabyte 970a-ds3
Corsair VS650
and 1TB HDD
I'll paste the most recent log here in "friendly view":
- System
- Provider
[ Name] Microsoft-Windows-Kernel-Power
[ Guid] {331c3b3a-2005-44c2-ac5e-77220c37d6b4}
EventID 41
Version 6
Level 1
Task 63
Opcode 0
Keywords 0x8000400000000002
- TimeCreated
[ SystemTime] 2019-10-12T14:29:58.908254900Z
EventRecordID 5325
Correlation
- Execution
[ ProcessID] 4
[ ThreadID] 8
Channel System
Computer Lord-Kek
- Security
[ UserID] S-1-5-18
- EventData
BugcheckCode 0
BugcheckParameter1 0x0
BugcheckParameter2 0x0
BugcheckParameter3 0x0
BugcheckParameter4 0x0
SleepInProgress 0
PowerButtonTimestamp 0
BootAppStatus 0
Checkpoint 41
ConnectedStandbyInProgress false
SystemSleepTransitionsToOn 2
CsEntryScenarioInstanceId 0
BugcheckInfoFromEFI false
CheckpointStatus 0
Restarts like that at load, typically point to a PSU issue. You haven't listed your PSU. What make and model is it?
It's very likely it's the PSU, specially as your system would be about 5 years old or so.
Getting a good PSU should solve the issue. I'd recommend a Seasonic Focus Plus Gold, EVGA G3, Corsair RMX/RMi/TXM 550w as a replacement.
Reactions: Blingbo
