Oook. After 20 years I switched from Intel to AMD. Now, when I'm benchmarking I see the temp is going aroung 93-95 degrees at 1.400V Vcore
In bios I set up negative offset - 0.060V and temp are around 90 C and 1.355V Vcore
I dont have experience with Asus bios. All my life I used MSI.
Any help and suggestions are welcome.
Note: AIO is set up very well 100% and plastic cover is removed.
No background processes
Good case airflow [3 front fans intake, 1 rear exhaust]
Cables are checked
Thermal paste normally attached
Rig
R7 7700x
Aio Artcic Liquid Freezer II 360mm
Asus ROG Strix B650E-E WiFi
2x8Gb ddr5 6000MHz Kingston
CM V2 850W Gold
Cables are checked
Rig
R7 7700x
CM V2 850W Gold
