Hey guys,
I recently bought another Galaxy GTX460 768 MB to hook the same video cards together.
My mobo is a Asus P6X58D Premium, with three PCIe 2.0 ports that have speeds of x16/x16/x1 or x16/x8/x8 (plus others). In other words, two blue ports and one white.
So I put both video cards next to each in the x16 slots, and connected the SLI bridge. After the drivers installed, all I did was go to the control panel and click maximize 3D performance/enable SLI. That worked out, but my temps were ridiculous, with the first GPU going up to 90+ Celsius. both cards were in x16/x16 ports, but they were literally .2 milometer apart from each other, blocking the 1st GPU's fan.
So I then decided to put the second GPU in the white x8 port, making the bandwidth x16/x8. The bridge is not long enough, however, but I then researched that the cards should work in SLI anyways without the bridge. I check the control panel, and the option is grayed out with two warnings underneath:
For maximum 3D performance, connect the bridge.
and
For optimum 3D performance, plug the second card into a high performance PCIe slot.
Both warning should not gray out the enable SLI option. If anything, I researched that the bandwidth makes no noticeable difference and the SLI bridge is not necessarily to enable SLI ( I just bought one off amazon already)
My thoughts from other posts and forums are this,
I should reset the CMOS, but i do not know how to do that on the mobo and I have a lot of overclock settings and other options which i do not want to mess up.
I also heard that Realtek NIC or the LAN network drivers were causing this problem and should downgrade them, but I could only find EVGA files.
I have the latest nvidia patch (275.33) and reinstalled twice with clean installs (which uninstalled all the nvidia drivers)
Anyone have any idea's?
and
