Question Help GPU not working
Jan 20, 2022
Was changing out my extension cables because I didn’t like the ones I had in the case, after turning the pc on I realized the 8 pin to the gpu wasn’t plugged in all the way. Plugged it all the way in while pc was on and it doesnt turn on. Black screen. Gpu fans not running. Everything else works, case fans, ram lights up but gpu does not, is it fried?
have you tried running again without extension cables in place?
many of them are lower quality and cannot handle providing the necessary power.
No I have not, I moved everything to different motherboard after bios updating and all that jazz, everything works. So I got another motherboard 5000 series ready on the way and should be here in 2 days with Amazon prime. Thank the lord. Other than that idk what really happened I’m just happy all my components are in tact and working.
