Help! Having a hell of a time figuring out if a MOBO I got works or not.
cdyshack14
58
I have a P8Z77-Pro /Thunderbolt that I got on ebay. I bought it because the seller was not a computer guy and was selling it because they found it "in a box". I noticed the heat sink was still on it, so I thought maybe they did not know that here was a processor on the board as well. Turns out that there was. An i7-2340k CPU! Not a bad score for $95 total.
I was planning to do an upgrade anyway, but now I don't know how to test to see if the board works.
Before testing, I got bored and built the whole thing. Added a Cooler Master 212 Evo heat sink, installed 4x4g Corsair Vengeance DDR3 1600mhz 9-9-9-24 1.5v sticks, am using a 750w modular Corsair PSU, and a PNY GeForces GTX 750ti video card. As well as a DVD burner, a sweet drawer thing I found on Amazon (http://tinyurl.com/Bay-Drawer), and a cool 5.25 how swap thing (http://tinyurl.com/ogejzs7).
I have a 256 Samsung 850 pro 256 SSD for my Applications, a 250gb Samsung EVO for my OS and some other main programs, and then a 2tb, a 1tb, and a 500gb spin drive for media and backup.
So, imagine that - I put it all together, turned it on - and nada...
So what do I do to make sure my MOBO is working?
I have a P8Z77-V LK as a backup, but I'll lose 2 SATA ports. But that is not crucial, as I have a 4 port USB 3.0 card from Antec I can use for a couple of external drives for backup purposes.
BUT - I'd rather this board worked. Oh! I also do not need the wifi on the mobo either, as I always prefer, as all should, to hard line my Cat6 cable directly from my router.
So, back to my original question, how can I test my mobo to see it it works without building everything? I keep getting all kids of different answers online...
Thanks, guys!
ps - I did remove the CPU to check for pin issues, and one was slightly bent, but I fixed it perfectly with surgical tweezers, so that should be fine.
there is something you can do to diagnose the problem. you can buy a "motherboard diagnostic card" just search it in google and you will see. it will give you codes in what is wrong with the motherboard. My guess is, is the guy who you bought it from knew that the motherboard didn't work. prob gave you a fried motherboard
