G
Guest
Guest
Hi
Ive just bought a new graphics card and Im not having much luck installing it :-((
my mobo is a "jetway 531CF" with a K6-2 500 cpu 64 mb,
the graphics card Im trying to get going is the "Absolute Riva TNT2 32mb, model 64, pci"
The problem is disabling my mobos onboard graphics
Ive been through the mobo manual to see if its just a case of altering a jumper setting but there isnt one, just an audio jumper :-(( and Ive also had a look in the bios to see if its just a case of altering something simple in there (ie "onboard graphics enable/disable"), but couldnt find anything. Ive also had a look on Jetways website but couldnt find anything there either.
What do I need to be doing to get my card to work?
Please reply in layman's terms
thanx in advance to anyone who replies 🙂
Mozzy
Mozzy
