N Noah_31 Commendable Nov 8, 2016 60 0 1,630 Jan 7, 2017 #1 How many 120 mm fans can I fit inside the Corsair 760T Black V2 ATX Full Tower Case? (I'm using the case for a gaming build I'm working on coming up with)
Solution Zerk2012 Jan 7, 2017 If you cant figure that out then not sure you should be trying to build a PC. More fans don't always mean better temps and I would be using 140mm fans in that case. Radiator and fan compatibility: Top: 3 x 120mm or 2 x 140mm, Front: 2 x 140mm or 2 x 120mm (2 x 140mm LED included), Bottom: 1 x 120mm, Rear: 1 x 140mm or 120mm (140mm included) https://www.overclockers.co.uk/corsair-graphite-760t-v2-windowed-full-tower-case-black-cc-9011073-ww-ca-205-cs.html#tech_specs
N Noah_31 Commendable Nov 8, 2016 60 0 1,630 Jan 7, 2017 #2 Here's my incomplete build https://pcpartpicker.com/list/rHv6KZ (And yes, I'm willing to spend $5000+ to get the parts) Upvote 0 Downvote
Zerk2012 Titan Ambassador Oct 6, 2014 22,348 2,429 104,240 Jan 7, 2017 Solution #3 If you cant figure that out then not sure you should be trying to build a PC. More fans don't always mean better temps and I would be using 140mm fans in that case. Radiator and fan compatibility: Top: 3 x 120mm or 2 x 140mm, Front: 2 x 140mm or 2 x 120mm (2 x 140mm LED included), Bottom: 1 x 120mm, Rear: 1 x 140mm or 120mm (140mm included) https://www.overclockers.co.uk/corsair-graphite-760t-v2-windowed-full-tower-case-black-cc-9011073-ww-ca-205-cs.html#tech_specs Upvote 0 Downvote Solution
