Question Help identifying screw type
Being as the side and the top of the case are one piece cases back than used rivets. Only the motherboard side had screws to open the panel.
On things like this I take to home depot and put it in a shopping card and go directly to the nut and bolts and find a match, best fit and than make it work.
Really hard to be sure from the super close up pics, but I was thinking the big one piece cover, personally.
Edit- I can see that I am incorrect as you can see out one side to the floor. You may well be right.
Hmm. Yeah, they could have been rivets, to be honest. I noticed one was inserted with the head broken off, which made it difficult to get the PSU in. Thankfully it dislodged as I was trying to push it in.
