[SOLVED] Help identifying this GTX 1070 card
MutantMike
51
I received some parts after a buddy did a new build. He stated it was a GTX 1070 that is all he stated
Number on board states "NVIDIA 180-1G411-DAAA-A01"
I'm not sure it might be a founders edition 1070 or hp 1070
Also why do you want to know who made this card is there a problem with it
also the accelero xtreme cooler is pretty good
Well I’m new to this and building a PC on a budget. I own a Zotac 1060 6gb but got this 1070 due to the owner having issues with something. He built a new rig and traded me a bunch of his old stuff.
So I need to test the chip, gpu, board etc and trying to decide which card to keep and which to sell to be honest
Yea i was thinking of its being a founders too looks like he replaced the blower cooler because blower gpus aren't that good and they are noisy and 1070 is a good upgrade from 1060 it is similar to 1660 ti performance
Thanks
Anyway to test this without actaully having it installed? I do not have a power supply yet
you can go to any pc shop and test it there
Thanks. I am in a place where the closes shop is 2 hours 🙁
I have the motherboard he pulled out of his Alienware. I have RAM, an i7 5820k he gave me. I worry about the power so I think since I am building I will just get me a good 750 watt power supply and put it together.
Not sure what type of board it is but I typed in the serial and it seems like is has a decent value so maybe it is good
Here is the mobo
https://www.dropbox.com/s/zm1x7gsz01tp059/mobo.jpg?dl=0
Here is the mobo
you are lucky it is a standard atx motherboard it have 24 pin connector and 8 pin for cpu
you don't need 750w psu 650w is enough but try to get a good quality one avoid cooler master,thermaltake and weird power supply names i would suggest :
corsair,evga,seasonic
Thanks I really appreciate it!!
So this power supply is out of the question?
Thermaltake SPD-0700NP 80+ Smart 700W Quiet Fan
don't buy that here is a psu tier list :
what is your budget for psu?
Well I have this i7 5830k and since the board is for anintel was thinking of just using that
My original plan since I am not a HEAVY gamer is to get a Ryzen 2600 but that would mean buying a board as well
On sale this week ($59.99) was thinking of this, is this ok?
EVGA - 700W ATX12V /EPS12V 80 Plus Bronze Power Supply
what it is the model of that evga psu
