Help, if I select control panel after boot - it crashes ex..
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support,microsoft.public.windowsxp.perform_maintain (More info?)
Hi all,
I noticed some time ago that sometimes when I select control panel right
after I boot into WindowsXP that it crashes explorer - explorer then
re-loads and I can access the control panel the 2nd time I try. If I use
other programs and decide to access control panel sometime into the windows
session - all is fine. I don't get it - I have run anti-virus and spyware
scans and all shows clear.
Has anyone experienced this problem before? Where could I explorer a
solution? Except for this minor thing - WinXP has been extremely stable for
me.
Thanks,
Wm
To repair all system files, go to Start/Run, and type (or paste in): SFC /SCANNOW (see: Description of Windows XP and Windows Server
2003 System File Checker (Sfc.exe): http://support.microsoft.com/default.aspx?scid=kb;en-us;310747 )
Mark L. Ferguson (NOT an MS-MVP)
FAQ for MS Antispyware version 1.0.509
http://www.geocities.com/marfer_mvp/FAQ_MSantispy.htm
marfers notes for windows xp http://www.geocities.com/marfer_mvp/chatNotes.htm
"William Cheng @work" <NOSPAM@sympatico.ca> wrote in message news:eGIvIQGRFHA.2540@TK2MSFTNGP10.phx.gbl...
> Hi all,
> me.
> Thanks,
> Wm
