I think i may have a connection issue. But it only affects certain applications and programs. For instance, Steam works, Origin works, blizzard works, Google chrome works perfectly however, Epic games doesnt work and Windows updates seem to also not work too and so does skype. I dont know what the issue is and have restarted my PC and my router several times already. I even unplugged my Lan cable, power cable to the router as well as restarted my pc by switching off the power supply. Nothing seems to help. If anyone knows how to resolve this issue it would be greatly appreciated.
I have also have also ran all applications and programmes listed above on my laptop before just to see if it was just my main PC and my laptop ran all the applications normally like they should.
Some information about my PC
CPU : I7 7700k
Motherboard : Asus z270 A prime
power supply : Corsair cx650m
currently using windows 10 Version 10.0.17134
Using Lan cable
i dont know if this is useful but this is my ookla test result
ookla internet test result
CPU : I7 7700k
Using Lan cable
