Hello everyone,
Please i have a problem, i have a laptop [ Latitude E5520] I5 2 gen with 4 Gigs of RAM with a broken display, i want to use it with an external monitor [17 inch 1280x1024] i know it's old and weird but it's all i have right now and can't afford to buy another one because this not my main computer. By the way this laptop has a Windows 10 system, after plug in the monitor it's only showing a black screen so i tried to switch the display to second screen only using the Windows + P shortcut. I was pressing this combo many times for a long time until i finally get the monitor connected to the laptop but my problem is Windows showing only 1366x768 and it's grayed out so i can't change it.
So yeah right now the screen resolution is not OK, everything is blurry. This laptop is using Intel HD Graphics 3000, when i disable graphics drivers windows starts showing me other resolutions and i can use the 1280x1024 which is the right resolution for this monitor. Without using graphic drivers laptop becomes a little bit slow and online or offline videos becomes slow and laggy. I tried to install windows 7 instead of 10 & changing the VGA cable and using another one and i tried to use VGA to HDMI also but without any success. Please if there is anything i can do to fix this problem i will be grateful.
Sorry for my bad English
Best regards
Best regards
