Hey, yesterday I built a new computer with an Asus P7P55D mobo, Antec CP-850 PSU, Core i5-750, and Radeon HD 5770.
1) When I plugged everything in, the computer 'clicked', and the power LED, graphics card LED, and PSU fan turned on for a millisecond and then turned off, subsequent attempts to turn on resulted in nothing until I turned the PSU off and then back on.
2) Checked ALL connections and re-plugged in things carefully, then repeated step 1 (same result).
3) I plugged in the CP-850 PSU to another computer: it worked!
4) I plugged in a crappy budget PSU to the new computer, the computer turned on and I heard a loud POP sound followed by a slight electrical/burning smell. The computer remained on but in my panic I turned it off.
5) I plugged in the Antec CP-850 back into the new build to be sure of things, and of course, the initial problem was there.
My theory: the motherboard is defective and the Antec CP-850 has some built in protection that won't power a defective board. The old PSU didn't have so this so it made something pop. This could be completely wrong though. Should I RMA the motherboard? Note: The standby power LED works.
Thank you so much for your help, I'll be sure to return the favour by helping out on these boards.
