Hello People from the internet, this is a first time forum thread for me but i'm out of options and i need someone to look into this problem with me.
So here's the deal. My CPU and GPU usage is around 65 % when i am playing games on my windows 10 pc. This means that not all the juice of the gpu and cpu is used. It does not look like a bottleneck to me because the cpu and gpu both run at around 65%. Im getting low FPS in PUBG, FORTNITE , BF5 , BF1.
Also i have not overclocked my GPU nor CPU. The only thing ive changed is set Power Limit to the Max and Temperature limit to the max in MSI Afterburner.
First my system specs:
GTX 1060 3G
MSI b350m Motherboard
8 GB dual channel 2400 mhz ddr 4 Ram from Kingston
240 gb samsung evo ssd
1 TB Hard drive
500 Watt Powersupply.
So ive done some research and these are the steps ive already done.
Changing the power management of the pc.
Changing the power management in Control Panel of NVIDIA. ( High Performance )
Disable HPET
Change Max prerendered frames to 1 in Control Panel of NVIDIA
Having Dual Channel Ram
Making A Config File For BF1 and 5 which limits the fps.
None of them solve the problem.
So the things i have not done yet are changing the powersupply because that can be faulty ofcourse.
I hope to hear from you guys soon. I cant figure this out on my own.
P.S i have vsync disabled
GTX 1060 3G
1 TB Hard drive
Disable HPET
