Question Help me build a Budget PC for BF6
Aug 6, 2025
4
Hey all,
I want to build a PC for the upcoming BF6 but alongside that, I will probably step out of console gaming and use it for other games too.
I'm in Australia, I'd like to build a PC that can run high settings at 60 frames or above. I have some questions.
Where's the best place in Australia to order all the needed parts and have them sent to me?
According to the specs list, for my desired outcome I require an RX 6700 XT/RTX 3060ti or above, an i7-10700 or Ryzen 3700k and 16GB of Dual Channel Ram at 3200mhz.
I haven't built a PC since 2011 (for BF3 lol) and I'm not up with the times. So, I was hoping someone could help me list the cheapest variants of CPU/GPU and Ram that meets these requirements.
I'm also unsure what wattage of Power Supply I need and I'm not sure how much the motherboard matters, but would love recommendations on which ones to get.
As for case, I guess that's a personal preference thing.
Also, is it possible to do this under $1000 AUD? If not, what sort of cost am I looking at?
Also, with the given specs, roughly how many years of gaming can I expect before needing to upgrade the GPU/CPU?
Cheers,
1080P
PCPartPicker Part List
CPU: *Intel Core i5-12400F 2.5 GHz 6-Core Processor ($159.00 @ Amazon Australia)
Motherboard: *Asus B760M-AYW WIFI D4 Micro ATX LGA1700 Motherboard ($169.00 @ Computer Alliance)
Memory: *Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory ($119.00 @ Amazon Australia)
Storage: *TEAMGROUP T-FORCE G50 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($85.00 @ Centre Com)
Video Card: *Gigabyte EAGLE Radeon RX 6600 8 GB Video Card ($289.00 @ MSY Technology)
Case: *Montech AIR 903 BASE ATX Mid Tower Case ($89.00 @ PLE Computers)
Power Supply: *MSI MAG A650BN 650 W 80+ Bronze Certified ATX Power Supply ($69.00 @ MSY Technology)
Total: $979.00
*Lowest price parts chosen from parametric criteria
Generated by PCPartPicker 2025-08-07 13:37 AEST+1000
https://www.tomshardware.com/software/windows/windows-11-free-or-cheap
Reactions: RBSBD
1080P
Total: $979.00
Hey thanks heaps for this, so this will run 1080P at 60+ frames? Seems reasonable enough! I had no idea I could get a decent GPU at that price either.
If I can find the i7 around the same price as that i5, should I get that instead?
Thank you again
Reactions: Why_Me
Thank you again
A i7 will give you more fps although you will want a aftermarket cpu cooler and a board with better VRM's.
Okay cool, if the i5 is going to be all I need then I'll go with that.
Also, I just looked at the i7 and yeah, definitely not within budget. Do you recommend a specific cooler or will any do the job?
Thanks again, I didn't know PC Part Picker was a thing. I'm not sure what VRMs are sorry but I'm assuming the board you listed has good ones?
Reactions: Why_Me
This will work fine for that i5 I posted.
CPU Cooler: *ID-COOLING FROZN A410 SE 55.2 CFM CPU Cooler ($35.00 @ PLE Computers)
Total: $35.00
Generated by PCPartPicker 2025-08-07 14:54 AEST+1000
Reactions: RBSBD
You would need to add some to your budget to meet your requirement of RX 6700 XT/RTX 3060ti or above
Yeah, I had a look and they're pushing the budget a bit. But if I can run 1080p with the 6600 I'm fine with that for sure.
Video Card: *MSI GeForce RTX 3060 Ventus 2X 12G GeForce RTX 3060 12GB 12 GB Video Card ($419.00 @ Centre Com)
Total: $419.00
Generated by PCPartPicker 2025-08-07 18:44 AEST+1000
