Hello guys, I'm about to buy a new brand pc after many years. The matter is that i'm kind of lost in all this 'build pc world', so I've been researching some components and end up with this possible pc:
Power supply: EVGA 600W 80 plus bronze
GPU: Amd Ati Xfx Rx480 4Gb Ddr5
CPU: I7 4790k 1150
RAM: Kingston HyperX Fury 8gb Ddr3
About the motherboard, I was planning on buying the Gigabyte ga-z97x Gaming 7 because it has the 1150 socket for the i7 but it's relatively hard to find where I live. Do you guys suggest me to try and buy that motherboard? any other suggestions?
This is planned to be used for gaming, possibly video editing at some point
Other big question is if all the pointed components are compatible with each other.
Hope you guys can help me and big thanks!
CPU: I7 4790k 1150
