[SOLVED] Help me choose between SFF cases
The Shift should not be taken into consideration...it's more of an AIO(starves the pump of fluid) and parts killer(heat trap). I'd pick the other two on any given day. You could also look into CollerMaster's NR200P case(and it's variants).
Of the two listed above, Meshlicious get's my vote, since I wanted that case since it was in the prototype phase but I already have custom built SFF cases that are pending a coat of paint and a build log.
