I need a motherboard for my future CPU:
Intel Core i5-4690K 3.5 GHz LGA 1150
I plan to overclock using a:
Corsair H100i GTX High Performance Liquid CPU Cooler
Here are 3 options, all of them look very good, and I can't decide which one is the best for my case.
Gigabyte GA-Z97X-UD3H-BK
ASUS Z97-A/USB 3.1
Edit:
MSI Z97A GAMING 7 USB 3.1
I'm not tight on the budget, so I appreciate if anyone have any other suggestions, but also I don't want to spend more than I really need.
■ The goal is intense Gaming.
■ I will use a single 980Ti and I have no intention on doing a SLI in the future.
■ I intent to do a moderate overclock on that CPU, it doesn't have to be an extreme overclock, but I also want to take the maximum advantage of my cooling system.
■ I'm planing to buy an appropriate case, once I choose the motherboard, so I'm not worried about that for now.
ASUS Z97-A/USB 3.1
Edit:
