Alright y’all, made an account just for this, hoping one of you can help.
I have a WD Sn770 2TB SSD that I used to use in the PC I currently own as extra storage for Steam. Long story short, the drive got removed at some point and while it was removed, the PC was reset.
I want to use the SSD again, but that’s where I run into problems. If the SSD is in the M.2 slot, the PC will not boot at all. If it is connected in an external enclosure that I know is working, it shows up in Device Manager and in Explorer, but if I try to do anything with it, the computer hangs. Occasionally I can get it to attempt formatting, either via the GUI or in CMD, but it always hangs before finishing.
It’s still under warranty, but getting it replaced by WD is kind of a pain and I’d prefer to avoid it if I can.
I’ve done all the troubleshooting I can think of, but if any of you kind people can help I’d appreciate it.
Thanks!
Thanks!
