[SOLVED] Help me, I am newbie
yun3515
37
Hi, I am new please help!
I want to upgrade my GPU under 400 dollars. What would be the best bang for a buck on this system.
FYI, GPU is so expensive why all old ones are still expensive?
Operating System: Windows 10 Pro 64-bit (10.0, Build 19042) (19041.vb_release.191206-1406)
Language: English (Regional Setting: English)
System Manufacturer: Micro-Star International Co., Ltd.
System Model: MS-7B33
BIOS: 1.40 (type: UEFI)
Processor: Intel(R) Core(TM) i5-8400 CPU @ 2.80GHz (6 CPUs), ~2.8GHz
Memory: 16384MB RAM
Available OS Memory: 16252MB RAM
Page File: 8404MB used, 10279MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
DirectX Database Version: 1.0.8
DxDiag Version: 10.00.19041.0546 64bit Unicode
Card name: NVIDIA GeForce GTX 1060 6GB
Manufacturer: NVIDIA
Chip type: GeForce GTX 1060 6GB
DAC type: Integrated RAMDAC
Device Type: Full Device (POST)
Device Key: Enum\PCI\VEN_10DE&DEV_1C03&SUBSYS_61633842&REV_A1
Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
Display Memory: 14177 MB
Dedicated Memory: 6052 MB
Shared Memory: 8125 MB
EVGA 600w bronze
