Help me overclock my 1100T Phenom BE!
Justenbphelps
9
The highest ive gotten it so far is 3.8 but after a week it crashed.
Please!
My specs:
Windows 7 Home Premium 64-bit
MoBo:ASUS M4N98TD EVO AM3 NVIDIA nForce 980a SLI ATX AMD Motherboard
BIOS: BIOS Date: 11/22/10 21:59:47 Ver: 08.00.15
Processor: AMD Phenom(tm) II X6 1100T Processor (6 CPUs), ~3.3GHz
Memory: 6144MB RAM
Available OS Memory: 6144MB RAM
Card name: NVIDIA GeForce GTX 460
Display Memory: 3809 MB
Dedicated Memory: 993 MB
Shared Memory: 2815 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: VE228
Monitor Id: ACI22FA
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: HDMI
PSU: Corsair 750W
Cooling: ZALMAN CNPS9500A-LED 92mm 2 Ball CPU Cooler + Three Case Fans
Justenbphelps
9
I was using CPu-Z to monitor. No burn in tests though. Never really thought about it! :/
I was just slowly upping the ratio and fsb till it crashed then brought it back down.
Processors
Number of processors 1
Number of threads 6
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 1
-- Core 2
-- Thread 0 2
-- Core 3
-- Thread 0 3
-- Core 4
-- Thread 0 4
-- Core 5
-- Thread 0 5
Processors Information
Processor 1 ID = 0
Number of cores 6 (max 6)
Number of threads 6 (max 6)
Name AMD Phenom II X6 1100T
Codename Thuban
Specification AMD Phenom(tm) II X6 1100T Processor
Package Socket AM3 (938)
CPUID F.A.0
Extended CPUID 10.A
Core Stepping PH-E0
Technology 45 nm
TDP Limit 126 Watts
Core Speed 3300.0 MHz
Multiplier x FSB 16.5 x 200.0 MHz
HT Link speed 2000.0 MHz
Stock frequency 3300 MHz
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V
L1 Data cache 6 x 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 6 x 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 6 x 512 KBytes, 16-way set associative, 64-byte line size
L3 cache 6 MBytes, 48-way set associative, 64-byte line size
FID/VID Control yes
Min FID 4.0x
P-State FID 0x15 - VID 0x06 - IDD 16 (18.50x - 1.475 V)
P-State FID 0x11 - VID 0x0E - IDD 16 (16.50x - 1.375 V)
P-State FID 0x9 - VID 0x12 - IDD 12 (12.50x - 1.325 V)
P-State FID 0x1 - VID 0x16 - IDD 9 (8.50x - 1.275 V)
P-State FID 0x100 - VID 0x1A - IDD 5 (4.00x - 1.225 V)
Package Type 0x1
Model 10
String 1 0x0
String 2 0x1
Page 0x0
CmpCap 6
ApicIdCoreSize 8
TDC Limit 96 Amps
Max non-turbo ratio 16.50x
Max turbo ratio 18.50x
Attached device PCI device at bus 0, device 24, function 0
Attached device PCI device at bus 0, device 24, function 1
Attached device PCI device at bus 0, device 24, function 2
Attached device PCI device at bus 0, device 24, function 3
Attached device PCI device at bus 0, device 24, function 4
OK. Your post suggests that you didn't touch any voltage settings. If this is true, then your stability can be increased by raising vcore, but first try this:
1. Raise the FSB until failure again
2. Set RAM to specs shown on the side sticker
3. Disable Cool n Quiet
4. Raise vcore by one level. Some BIOS allow you to press the "+" key; some require you to use the up/down arrows. Either way, just increase vcore by one level (key stroke) at a time.
If this doesn't help, there may be need for additional steps. You may need to adjust the Northbridge multiplier; you may even need to lower your RAM frequency.
Edit: To make this clearer, increase vcore one step at a time and test the OC settings in Windows. To test for stability, download, install, and run Prime95. Run this test on blend for about 1/2 hour.
Justenbphelps
9
My temps have not risen over 40* for the cpu yet.
So i hit a ceiling just now.
The blue screen of death. These where my settings when i hit the screen:
4.06Ghz (4066Mhz)
19.0 Multiplier
220 FSB
1.4125V Cpu
scared the Sh** out of me, never had that blue screen!
But i lowered the multiplier and FSB back down to the ones from above post and it recovered just fine. Im going to try and raise the Vcore to 1.44 with the 19 and 220 right now...
UPDATE: I ran Prime95 at 3.8Ghz with the accompanying settings i mentioned, and it gave me the blue screen of death. So i rebooted and upped the Vcore to 1.450 and it succesfully booted again.
OK Another UPDATE!:
After these screenshots i attempted to watch a youtube video and another Blue Screen Raped my monitor.
What is the reason my computer crashes anytime something even mildly uses the CPU? Do i not have enough voltage to the cpu?
And why does it mention a memory dump? should i be worried?
The Most Current specs:
Im a bit nervous to run the prime95 right now...
cuecuemore
You need to back up and stress test at a reasonable setting. Set it to 3.7 and then run prime95 until your temps level out or you crash. If you BSOD, up the voltage a bit and repeat the stress test. If it passes, up the frequency, test, repeat, etc.
BSOD is typically the result of some problem with your RAM. First set your RAM to the specs shown on the sticker. If after you've increased vcore (not to exceed 1.5v) you still get BSOD, try lowering the RAM frequency.
Remember, your actual RAM speed is the bus speed multiplied by the RAM multiplier (or ~ratio).
