Clash77 Aug 7, 2021 1 0 10 Aug 7, 2021 #1 I was playing csgo when suddenly my fps dropped to 20 and a few seconds later my pc turned off.I went to the BIOS and saw that my cpu temperature was going up..A minute later it reached 100 degrees and my pc turned off again
Solution S S SamirD Aug 7, 2021 Check your system's fans and cooling--something broke. Your PC shut off to protect itself from thermal damage.
D drea.drechsler Champion Oct 16, 2017 9,841 2,647 54,790 Aug 7, 2021 #2 System specs, to include CPU, memory, PSU, motherboard, GPU. Also include cpu cooler, case and fan arrangements. First thing to check is your CPU cooler: is it's fan turning? if an AIO is the pump turning? Upvote 0 Downvote
S SamirD Judicious Jan 16, 2014 6,610 956 35,940 Aug 7, 2021 Solution #3 Check your system's fans and cooling--something broke. Your PC shut off to protect itself from thermal damage. Upvote 0 Downvote Solution
