D dominic phatsimo Reputable Feb 20, 2015 1 0 4,510 Feb 20, 2015 #1 Failure configuring Windows updates. Reverting changes. Do not turn off your computer" error when you try to install Windows updates
Agera One Splendid Apr 11, 2014 2,336 2 21,765 Feb 20, 2015 #2 Do disk cleanup and delete the unwanted files. Clean junk files and do registry error fix using CCleaner. Restart your computer. Then check check, download and install windows updates again. Upvote 0 Downvote
